another light on existing switch. | on ElectriciansForums
Discuss another light on existing switch. in the UK Electrical Forum area at ElectriciansForums.net
scrivs
stockport
hi
I am wanting to put another led light from a switch that is already being used, is it ok to drill through the side of the metal back box and wire in the blue and brown wires.
It depends how the switch is wired.
If theres a neutral at the switch, then its possible....
If its only a live and switched live, (which could be a brown and blue) then, no you cant. You need a neutral
Reply to another light on existing switch. in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I have dismantled my DEFENDER POWER POD 3KVA 110V TRANSFORMER & upon re- connecting the wiring, there now appears to be 2 extra wires...
