room one has 4 down lights and 1 switch
room two has 2 down lights and 1 switch
consumer unit has no spare ways
3 options on how to wire
option 1 : loop in and out from switch (3 cables at switch)
feed from mcb >>> light switch room 1 >>> room 1 lights
>>> light switch room 1 >>> light switch room 2
option 2 : loop in from 1st light (requires two joint box's at 1st lights )
feed from mcb >>> 1st light room 1 >>> 1st light room 2
>>> 1st light room 1 >>> light switch room 1
>>> 1st light room 1 >>> rest of lights room 1
option 3 : two feeds from the same mcb to each room
feed from mcb >>> light switch 1 >>> room 1 lights
feed from mcb >>> light switch 2 >>> room 2 lights
Q1)which way would you wire it????
Q2)would option 3 be a spur from a spur or bad practise?? i'm thinking it would be ok as neither would be able to pull more then 6 amps
