Another Nagy production covers controversy subject | Page 3 | on ElectriciansForums
Discuss Another Nagy production covers controversy subject in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
3rd part work / certification of A another’s job (skip the intro start at 2min45)
In the south of Ireland there is a procedure in place to deal with precisely these types of issues so that a DSO supply can be obtained.
This is the Change of Contractor procedure. The person responsible for the installation applies for a Change of Contractor to RECI with the details of the installing contractor and the new contractor. If the details of the installing contractor are filled in as "unknown" then the Report Illegal Works procedure is automatically invoked.
RECI will contact the original contractor to establish why the job has not been completed/certified, and will then authorise the new contractor to complete and certify the installation. Only after written permission has been received can works begin.
The new contractor will complete the job, carry out Pre-Connection Tests and send an Inspection Request form to RECI. RECI will then send out one of their Inspectors to carry out initial verification again with the Registered Electrical Contractor (REC), and compare results to the Test Record Sheet.
If there are non-compliances then an additional Inspection will be mandated. Each of these Inspections will cost €250 (in addition to the contractor's time).
Once RECI are happy they will authorise the new contractor to submit a Completion Certificate for the job. Once the job has been energised by the DSO (ESB) then the contractor will return to carry out Post-Connection Tests.
It is a serious disciplinary offence (which can result in dismissal/de-registration) to certify anyone else's job without specific written authority from RECI.
My ‘reaction’ to your post, was more informative than like. That sounds a very thorough system, but it also sounds expensive and convoluted.
Something in between, would be more appropriate IMO. I wonder if that system is followed to the letter, in simpler domestic installs?
I've had this scenario a couple of times.
1st time I think I posted the q on here, but 1st fix was done, place boarded out and plastered. Wires in wrong places, all seemed sketchy. On that occasion said EICR is all I'd sign. They found another who would provide EIC and notify.
A more recent job, 1st fix 75% done, but I was able to see cable runs etc, on this occasion happy to issue EIC.
Can't see any point whatsover in pulling out cable, just to pull in new in the same place!
This
Judgment on each individual job in hand is required
If someone on here said to me
‘Lee I have partially wired this job but am going away can you finish it for me and you take on the job please’
Of course I would finish it and certification it on completion
If however Dave down the pub said
‘Lee I have completely rewired my gaff and put in a new consumer unit can you give me a certification for all the work’
I would be rather more cautious
What you need to understand is that almost all work in a domestic property is classed as "Restricted Electrical Works" (aka designated works), which means that it is a criminal offence for anyone other than a Registered Electrical Contractor (REC) to carry out that work. The penalties are (from memory) up to €15,000 fine and/or up to 3 years imprisonment.
I always insist upon the Change of Contractor procedure being followed before taking over a job. I would hope that all RECs do the same, and would expect any not following the RECI Rules of Registration to be severely dealt with. Otherwise we don't have a level playing field.
I can see TNs point, ultimately about consumer safety - if you've done your checks and got acceptable results, where's the issue?
I would like to think that if NICEIC kicked out TN and he took them to court, the fact that he was reducing exposure to risk (for the occupant), that would be grounds to win an appeal as it put people before profit, but then again money talks and BS walks
Does the system work, the Part P one over here, doesn’t seem to work?
What about alterations & additions. I'm just curious.
Obviously an installation which is already energised poses the danger of illegal work being carried out. However there has been an advertising campaign to alert homeowners that non-RECs are not registered, insured, audited or inspected and that they are breaking the law. Furthermore there have been a number of prosecutions including six months' imprisonment to focus minds.
I should point out that an installation which has been de-energised but has been previously energised (due to someone selling the house; bank taking ownership etc.) only requires a Test Only Completion Certificate to be submitted and does not require a Change of Contractor procedure. The CC procedure only applies where Controlled/Restricted Works have taken place but haven't been certified (e.g. due to Contractor going bust or sleeping with the fishes etc.).
You would think that between EAWR and HASAWA you have concrete defence for finishing off third party works - The minute you set into the property it is your workplace and as such you are taking measures to ensure yours and others safety - The fact that NICEIC don't like it is tough ----, you're got legal grounds to take such action and I'd love to see a scheme in court for kicking someone put for doing thier job.
Reply to Another Nagy production covers controversy subject in the UK Electrical Forum area at ElectriciansForums.net
