Any Ideas Whats Happened To This Switch? | on ElectriciansForums
Discuss Any Ideas Whats Happened To This Switch? in the DIY Electrical Advice area at ElectriciansForums.net
None of your business
Hi All,
This morning we had a power failure of our shower. When I took the switch off the wall to check for any issues I noticed a section on the load side had "blown" for want of a better word.
I'm assuming its something to do with overheating but not sure - any advice?
Thanks,
Josh
  • [ElectriciansForums.net] Any Ideas Whats Happened To This Switch?
Failure of switch. Simple.
What brand of switch is that?
Replacement required.
Well the wire terminations were fine, looks like the internal switch contacts overheated going by the bulge in the centre of the plastic.
Assuming your shower is 11kW or less if it's under warranty return it for replacement otherwise just buy a new switch. If your shower is more than 11kW then you need a higher rated switch.
Reply to Any Ideas Whats Happened To This Switch? in the DIY Electrical Advice area at ElectriciansForums.net
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
