Discuss Any recommendations for a good quality Torque Screw driver set please? in the Electrical Tools and Products area at ElectriciansForums.net
Was just looking at a set of those - thanks. Is it possible to adjust the Torque settings or are they set to a unified standard, with all manufactures being set to the same setting?I'm a fan of the Wiha. If you can try a few different ones out before buying to see what suits you best.
Very easy to adjust providing you remember to push the torque setting driver (one with the black handle) in fully and make sure you only use it with the big red bit installed - I didn't first time I used it and nearly sent them back until I realised my mistake....Was just looking at a set of those - thanks. Is it possible to adjust the Torque settings or are they set to a unified standard, with all manufactures being set to the same setting?
Thanks for the info!Very easy to adjust providing you remember to push the torque setting driver (one with the black handle) in fully and make sure you only use it with the big red bit installed - I didn't first time I used it and nearly sent them back until I realised my mistake....
I went for the following set (appeared to be best value at the time), but to be honestly only real use the PZ/SL bit for torqueing up inside the CU.
Wiha TorqueVario VDE Interchangeable Torque Screwdriver Set 1-5Nm 11 Pcs - https://www.screwfix.com/p/wiha-torquevario-vde-interchangeable-torque-screwdriver-set-1-5nm-11-pcs/2581k
Wera on order - thank you all.I have a Wera. Comes in a nice roll to hold multiple blades and very easy to adjust. I'm not a spark, so it's not used regularly, but qualtiy seems to be top notch.
Think there are a few variations of this driver, with different torque ranges, so you'd need to choose the one most suited for your work. I think the one I have is adjustable from 1.5-3.2Nm.
Wera do two versions, one which I have is 1.5-3.0 Nm , the other is 1-7-3.5 Nm.
I looked at mine, it’s actually 1.2Nm to 3.0NmCouldn't remember the exact torque range, but I must have the same driver as it drops a few clicks below 1.7Nm.
I believe there are three different options.
Reply to Any recommendations for a good quality Torque Screw driver set please? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
