G
GBDamo
I have a lovely Ameg set, used less times than my old fella, and if you'd seen my face you'd know how few times that is...As above
JB
Discuss Any recommendations for a good quality Torque Screw driver set please? in the Electrical Tools and Products area at ElectriciansForums.net
JB
love Wera, best screwdrivers out there in my opinionHad to go and check as this was niggling me and it is indeed 1.2-3.0Nm.
I got this set as an Amazon warehouse deal - as new for about £15 more than the driver on its own. Went with Wera as I had a couple of handles and all the blades I needed, so ended up with doubles of most. The torque driver has only been used for one job (wanted to ensure I hadn't squashed conductors to within an inch of their existence), but can not fault the simplicity or quality of it. The regular handles get used a lot and, again, I can not fault them - blades locate as solidly as the day they were new. I guess the only issue with Wera is whether or not people find the handles comfortable, but they suit me just fine.
Do most sporks actually use a torque screwdriver , I honestly can’t say I have ever seen one used on site ...
I think that is the Wera one I have.I looked at mine, it’s actually 1.2Nm to 3.0Nm
Wasn't overall impressed with it either fairly poor quality for the price. Have a wiha one also which isn't bad but you have to take he bit of to change torque. Wera one looks goodI went for the armeg, must say not overly impressed, had a few 3.5mm flat heads snap, and a +/-1 also the foam in the carry case stopped gripping all the bits after a year
I’ve looked at the wrench for doing mccb’s, pricy but I suppose if you want to torque them, then that’s what you need.I think that is the Wera one I have.
I also have a 1/4" drive torque wrench and 3/8" torque wrench that allow me to cover up to 25Nm or so for the likes of M8 on bigger switchgear, but they are not insulated so I always feel very uncomfortable using them on electrics (instead of mechanics) even after proving dead...
For DIN rail terminals and a few other things I was thinking about getting the next one down, think it is 0.3 to 1.2Nm and takes the same 9mm insulated bits.
Reply to Any recommendations for a good quality Torque Screw driver set please? in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
