OP
Octopus
there is an automatic insulation resistance test that does tests between all conductors automatical switching between them when you have all your croc clips on the corrasponding conductor... when on this setting it shows up as >30.0 across all if there are no faults...
Would this raise any eyebrows by anyone who was to look at this in the future... if i wrote >30.0 in all boxes on my test results sheet..
I know its very common to put >200 on results for IR tests, My meter when done manualy across conductors shows >1000...
But if i did the Auto setting would there be any problems with putting >30.0
There is no problem with >30 on all lines, why should there be?
