Any tips on wiring 3x 2.5mm cpc's into a 13a socket? | Page 2 | on ElectriciansForums
Discuss Any tips on wiring 3x 2.5mm cpc's into a 13a socket? in the UK Electrical Forum area at ElectriciansForums.net
Durham
Every time i go to do this, even with correctly fitting sleeving, it seems to be a right **********")ÂŁ"$$* of a job getting all three in snugly without the sleeving riding up and making it difficult to tell whether i clamped on sleeving or copper.
Any tips for not fighting with this? It just took me like 10 minutes to put the cpc's away in a socket with a spur coming off it because i couldn't be 100% i'd got all three in correctly.
Don't most socket plates come with 2 earth terminals these days?
I'm sure the ones we spec do.
Some do, some don't.
Also the back-box terminals are often smaller so harder to get 3 wires in to make it worth doing, let along 4 as a common point. A Wago to link them and then single to socket would be easier.
See plenty old skool sparks wrap the earths under the fixing screw rather than use the box terminal
Anyway, K2746 (with outboard rockers) will have 2 earth terminals.
I think those were the ones intended for "high intergity" earthing for IT use (RFC or looped CPC with separate terminals for eacy connection so loose screw only breaks loop, not allowing anything to be CPC-free), as well as lower risk from accidentally switching off to loads by mistake. Cost a bit more though.
They are indeed.
Hi what do you mean by IT? Racking my brain here and can't think what you mean.
Reply to Any tips on wiring 3x 2.5mm cpc's into a 13a socket? in the UK Electrical Forum area at ElectriciansForums.net
