Anyone else use Haeger CU's...? | on ElectriciansForums
Discuss Anyone else use Haeger CU's...? in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Just curious if anyone else uses Haeger CU's for domestic..?
Been having probs getting my usual MK, so have gone for a couple of Haegers this week, ended up being ÂŁ10/ÂŁ15 more than mk inc with vat and mcbs. Easily paid for itself with the time I saved.
Only really used Haeger on bigger commercial industrial stuff when subbing years ago, was always good back then
Well worth it sticking with them in future - loads of room, everything in the right place, solid as - no earth bar springing out or MCBs cracking if you tighten them up a little too much. Even the knock outs and labelling simples, not the slighest bit fiddley
Just thought I'd share that with you :39:
Used hager for a few years now with no problems.the mcbs will fit older hager boards as well.take note mem, square d et all with your rip off practice of making boards obsolete and then charging a kings ransom for an rcbo to fit an existing board.fitted a few mk boards recently and found faulty rcds and a faulty main switch straight out of the box, just the ticket when your 50 miles from home.I'll stick with hager I think
Heard a few of the guys saying recent problems with MK stuff, not good for UK company :(
Why would you tell me that!!!
Look what I've just started to put in at home... :banghead:
[ElectriciansForums.net] Anyone else use Haeger CU's...?
I used an MK CU recently and was disappointed with it, as it was fully loaded 15 way(i think) and found the row of MCB's sagged in the middle making it a PITA to get the lid on.
I usually use Hager or Crabtree,
I use hager for all domestic jobs not a bad board and never had to go back to one yet for a fault. Although I did have to go back due to the RCD tripping and customer not being able to find out why, turns out the mrs had poured water on the base of the kettle which was still plugged in.
Always keep hager's in stock and breakers tons of room in them too
I use Hager all the time
I had a MK consumer unit, and used MK until 2 years ago. Put in a Hager after I started using them
MK are now very poor build quality and unreliable - ended up getting 2 faulty MCB's a month (not latching) before I ditched them
I have used Hager for ages now and really like the quality- they cost more, but you get what you pay for.
I like the fact you can buy neutral links, and neutral bars as spares-means you can fit an extra RCD and MCB's in if you want to add in storage heaters in to the same enclosure
On new build domestic we only ever used to use Hager and up until recently only type i ever have, fitted 1 wylex and dont like them breakers slide on din rail and sag so cover hard work to get on have to keep budging the breakers up to get the cover back on first and last time i fit one
Reply to Anyone else use Haeger CU's...? in the Australia area at ElectriciansForums.net
