Anyone know why this capacitor was installed? | on ElectriciansForums
Discuss Anyone know why this capacitor was installed? in the UK Electrical Forum area at ElectriciansForums.net
I'm currently working in a building that was completed in 2006. All the lighting is switched by wall mounted PIR and these capacitors seem to be installed at every PIR connection behind a blank plate. The capacitor is connected between the switched line and N Just wondering if these were needed for the old lights as every light is LED now?
[ElectriciansForums.net] Anyone know why this capacitor was installed?
I'm currently working in a building that was completed in 2006. All the lighting is switched by wall mounted PIR and these capacitors seem to be installed at every PIR connection behind a blank plate. The capacitor is connected between the switched line and N Just wondering if these were needed for the old lights as every light is LED now? View attachment 117801
There was probably a relay, inductive load involved, so used a capacitor for induction suppression.
Caps were also required when the lights were a small load to operate correctly with some 2 wire PIRs and timer switches that have no neutral connection. The timers current draw would be enough to make some fluorescent lights flicker etc.
Looks to me like it's being used as a snubber to prevent the LEDs from glowing even when the switch is off, due to the effect of capacitance in the cables.
The op said it’s leds now so I assume it wasn’t before
The capacitors installed between the switched line and neutral were likely added to prevent flickering or false triggering with older lighting systems, particularly with fluorescent or low-wattage bulbs. With your current LED lights, these capacitors might not be necessary. To check, you can disconnect one capacitor and see if the LED light operates correctly without flickering or false triggering. If everything works fine, you can consider removing them.
Hope this helps!
Reply to Anyone know why this capacitor was installed? in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
I tested the supply with my AVO, I also confirmed the PIR has the same supply coming out. Readings are 247 Volts on both. This was tested between...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
