anyone reccomend a termination box | on ElectriciansForums
Discuss anyone reccomend a termination box in the UK Electrical Forum area at ElectriciansForums.net
sima24
Hi guys, as title really, i need to terminate 4 25mm swa's on the outside of a 5 floor building and wondered if anyone has done something similar and could you recommend a product. Looking to terminate the swa into an ip rated enclosure and then run twin tails from their straight through the wall into the new cu's. Does anyone know of an enclosure with built in henleys? Thanks.
Why connect in the enclosure. Strip the outer cable insulation and steel wire and run the remainder through the wall in ducting with whatever earth required from the enclosure.
Reply to anyone reccomend a termination box in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Sounds more positive.
