Anyone seen this symbol before? | Page 2 | on ElectriciansForums
Discuss Anyone seen this symbol before? in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
[ElectriciansForums.net] Anyone seen this symbol before?
Logo in the bottom right corner - looks like I shouldn’t be installing them in a home.
Also - 30 of them needed per lamp at 15w each - two lights (one already installed by customer) + other lights.
It’s right up close to maximum demand - even with diversity.....
Customer supplied lamps - time for a chat - but to put LED’s in will cost £££££
He also wants them dimmed.
So that’s 900 watts through a dimmer. I think they are rated to 600 Watts max.
In a 16mm box.
Oh dear.
Other than that a relatively straight foreward day!
Tricky one, there were a few 1kW dimmers around but that would be a lot of LEDs, so they're mostly disappearing.
The Varilight HQ9W is rated at 1kW, MIs 'recommend' 25mm box so it might squeeze into 16mm, doubt it though.
This Amazon seller lists the HQ9W, here.
If your customer complains about fitting a deeper box a 10mm spacer would look tidy enough.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Thanks for that. Interesting.
I was going to fit a deeper box, in fact I've several to do on the house, and I hadn't really quoted for chasing back, and its all just been painted.
Trouble is the proposed dimmer switches are brass or chrome. Might look a bit naff with a spacer.
Pushing for LEDs though. He'd get his money back within a couple of years at the very most. I've just done a calculation for him.
You're right, LEDs would make sense, although otherwise you might get a steady stream of work replacing blown oven lamps.
Agree that a spacer wouldn't look good under a brass dimmer, just had another look and see that TLC stock the 1kW Varilight with a brass plate.
Since changing to LED's in all my fittings I have saved over £100.00 in two years in replacement costs alone, not sure on the electricity savings, but must be near the same, false economy to use any other type of bulb in a chandelier that big IMO.
Reply to Anyone seen this symbol before? in the UK Electrical Forum area at ElectriciansForums.net
