Anyone tried these? | Page 2 | on ElectriciansForums
Discuss Anyone tried these? in the UK Electrical Forum area at ElectriciansForums.net
I must be lucky, last job I did, first fixed cables, came back with no interaction with guys doing the boarding (customer was project managing his own project), expect a nightmare finding cables etc....instead....level lines drawn, 80% of cables pulled through holes, others marked where they were....only niggles - socket ring in the utility room extension had a 2.5 spur to an SFCU for an exterior light, instead of drawing all 3 cables out at once, they had drawn them out in 2 separate holes (no one had considered to phone the spark to ask why there were 3 cables there.... oh well 2 holes for the plasterer to sort, stuck the socket backbox dead centre between the 2 holes...where I had planned for it to be all along.)
Other niggle was for the living room lights (fcu off the living room ring at socket height to light switch at normal height - underfloor heating so couldn't go below, customer had laminate floor above so couldn't lift boards upstairs) Feed cable was below a noggin, supply cable above it, ended up having to remove the plasterboard from that wall (thankfully not skimmed etc, just screwed in place) to get the feed cable above the noggin, after spending 25 mins trying to pull it up through the drylining box hole and removing the skin from my knuckles from the harling on what was once an exterior wall behind the plasterboard.
Also the geniuses removed a socket and joined the wiring with 5amp terminal strips...well the live and neutral, the earths they just left alongside each other..........
Just had an idea - not sure if it will work - but will try it today and will update the forum.
mount a round dry lining back box in the roof to insert cables. Pendant mounts directly to the back box and terminates easy.
i can't see any reason why it would not work as long as the holes match up.
it won't matter then if the cables are pushed in, just cable tie the end or take back box off and fish around.
also could solve the problem with trying to get a secure fixing.
thoughts on this please
These things are only made from corrugated card, wonder how much moisture from new plaster they can take before falling apart.
I use the yoozy boxes, at leat they can be reused time and time again
I do something similar for wall lights. I use an architrave box sunk into the wall to give more room for looping cables etc
For lighting cables that have to come through the ceiling, just put a noggin in between the joists flush level with the joists and drill a hole in it where the cables are to come through they can't board over them then!!
Reply to Anyone tried these? in the UK Electrical Forum area at ElectriciansForums.net
