K
KevinS
Got a call out today
No power at db
I had 240 going into the apex voltage optimiser but nothing coming out. Status LED was flashing green then red
Does anyone know if the unit needs resetting (and if so how) or is the unit given up
Also does anyone have any instructions for these units
Thanks in advance
PS got the power up and running by by-passing the unit
Thanks again
Long story short: There are no ways to save on a consumptions other then Using things better (less often) or using better things. (more efficient).
While there is a minor chance for negligible reduction by reducing voltage, this will most likely be less then devices internal consumption (by producing heat and buzzing noise). (Explanation of why lowering voltage on high currents (>3Amp @ 240V) is inefficient is better for a video or full on article.
If you want to reduce consumption here are some tips:
-Where possible make heat from GAS rather then electricity. (In UK major part of Power is made from gas, most of power is wasted and few more companies earn extra on-top so it is unlikely that Electrical heating from grid would ever compare). Which means HOB and shower cost a fraction of the cost when done with gass.
-Insulate, Insulate,Insulate
-Use switches/smart bulbs rather then dimmers (dimmers waste lot of power often using more then having light full on)
  • Use efficient equipment and Use it on less then its maximum (most things are most efficient between 40-75% of their power, but this obviously ranges).
  • Apply power to only what you use (EG only as much water in a cattle or pod as you need).
There are some e-bay special devices which work on a power factor basis, but their blue LED usualy uses more then they save . And even that saving may actually be more consumption..
this might warrant its own forum...
You are lucky to get 40% efficiency from burning fossil fuel to actual electric output, where as a combi boiler is often above 80% efficient in terms of heat from the fuel input. Hence the traditionally lower cost and less environmental impact of gas heating (or CHP, but no one wants to be near the power station, etc)
But as we (hopefully) get more electric from low-pollution means that balance changes and at some point getting gas to feed the network is going to become far more expensive. At that point the best choice would be heat pumps and top-up electric heaters.
But for now that is not the economics of the world, hence the use of subsidies and political decisions to mandate changes that in the short change cost more to install and/or use.
One of the best solutions is obviously to use less, but the cost and difficulties of retro-fitting insulation (not to mention the debacle over the Grenfell tragedy putting the spotlight on dangerous insulation and the eye-watering costs of rectifying it) mean the majority of the UK's property ain't going to be changed any time soon :(
While it's drifting somewhat off-topic now ...
We live in an ex council house of 1940s vintage. Well built, good sized rooms, decent garden - i.e. the opposite of modern rabbit hutches in all but thermal design. It's been upgraded with cavity insulation, uPVC framed double glazing, loft insulation, central heating - basically all the standard things to do.
As we've been going round the rooms changing the decor to something acceptable, I've also been fixing some fundamental issues with the heating.
The original house had small radiators, which didn't even keep the place warm with a (non-condensing, that's on my list) boiler running at a high temperature. I've mostly replaced them with the biggest practical radiators I could fit - subject to constraints of space etc. In one room I had to buy online as the local wholesalers told me that they don't do anything over 2.4m long, I've got a 3m long (but only 450 high) rad in teh living room. As to the designer "look nice if you like that sort of thing, but absolutely useless at heating the place" things the previous owner put in the extension, the least said the better ?
Anyway, I've been running the heating circuit at 40˚C since I got the thermal store in, and in this recent cold spell it's not quite been enough to keep the place warm. So if someone comes along and tell me I have to replace the boiler with a heat pump that doesn't work well above 30˚C and will cost me a few years of heating bills just to install and cost more to run - well they'll get a fairly strongly worded rebuttal of their policy ?
Caution - rant mode on, look away if you are easily offended ...
But at least we are owner-occupiers so it's (mostly) our choice what to do. I'm also a landlord, and luckily both our properties are either already band C or only need minor adjustments (like the assessor actually noting the existing heating controls rather than recommending them as an upgrade ?) to make it - because that's what's being proposed for a few years down the line for all privately rented properties. F**k knows what the idiots in London think is going to happen to a lot of properties that won't be easily upgraded - especially the ones where upgrades would destroy the character some people are specifically looking for in some older properties.
Needless to say, housing associations are going to be exempt from this. I can only assume that a relatively small number of large businesses have more of a voice in Westminster than millions of "little people".
And I've yet to hear what is supposed to happen during those cold spells - like we've just had, and like the prolonged one at the end of 2010 - where wind and solar are AWOL, we've not built much (if any) new nuclear, and so most of this lecky we'll be forced to use to heat our homes will be from fossil fuel. Oh yes, the smart meters will either hike the price to persuade people that staying warm is an optional luxury, or if that doesn't work, they'll cut us off - all for our own good of course.
For that time when gas is no longer generally available, I subscribe to the Christina Perri plan - I'm collecting jars of farts.
Well that suggests an alternative plan - we all start eating lots of baked beans* and heat the house with methane ?
* Others have different "best choices" - I know some who swear by (at !) brussel sprouts in the gassification stakes.
Apex domestic voltage optimiser
Domestic Electrician Forum
KevinS,
Simon47,
TrueNAS JBOD Storage Server
