A
adam.h
For integrated / fixed appliances, having a fused switch spur can you then run t&e to a ko box behind the appliance and connect the flex to t&e via a terminal block? covering with a blanking plate.
Discuss appliance flex to t&e in the Australia area at ElectriciansForums.net
What does the appliance instructions state. It might state that it has to have a BS1363 plug-top.
Yooj
Most instructions also state " if in doubt consult a qualified electrician"
As a plug top is an accepted method of connection for those less qualified, I don't see a problem with a fused spur unit and a flex outlet plate as an alternative method of connection
disconnecting the flex from the spur would require isolation of circuit and removal of the face plate to disconnect the flex
Yooj
This is the reason that all appliances which are fed via a plug-top have a moulded plug-top fitted by law to the flex, mitigating the need to cut the plug-top off, strip the flex and connect to a terminal block.
That aside, I stand by the fact that doing it this way is a poor design simply because a plug-top is an accepted method of isolation for lay-persons, there is no need to disconnect cables for maintenance etc, and a flex outlet plate solution is a more expensive one than a socket-based solution since you now need to factor in the flex outlet and an FCU instead of just a socket and DP switch both of which are cheaper than the respective alternatives.
You have to ask yourself what is being achieved with FCU and flex-outlet method in terms of safety and functionality...I would say the nett gain is zero, or less than zero, since you now have the added time to wire in the appliance instead of just plugging it in. Then you have the nett-loss for the cost of ownership, since any subsequent maintenance/repair which requires the appliance to be removed/replaced now needs it to be disconnected rather than just unplugged.
Whilst the FCU/Flex outlet is not an issue, it just unnecessarily adds costs and complicates installation for no quantifiable benefit.
Reply to appliance flex to t&e in the Australia area at ElectriciansForums.net
