Sorry for the confusion once again, i of course meant oven when i was referring to supplying ot fro the kitchen ring main. This isnt a job i can walk away from now and although the customer can be hard work so far i have had no problems with payment
Discuss applying diversity in the Talk Electrician area at ElectriciansForums.net
I dont want them to go and buy say two 10kw rated showers as the chances both showers getting at the same time are quite high as they have a guest room for relatives who stay over regularly.
Well i think you worrying way to much pal, water pressure isnt powerful enough to run 2 showers at the same time unless some serious pumps are installed.
Have you been to the property and tested the water pressure then?
Is it not? So oven arrives complete with 13a plug top and is less than 2kw and i cant plug it into the ring main?
Yes i have 3 bar
Where the hell is Soul on Trent anyway?
Sounds like the frozen north to me, somewhere the wrong side of the Watford gap
It might have been an idea to give this bloke a hand with his designs whilst you were there then. Or at least give us a clue in your post that you had actually measured the water pressure at the location.
whos been checking my profile out then, cheeky!
Reply to applying diversity in the Talk Electrician area at ElectriciansForums.net
