T
TPES
TT Supply.
Main CU, With earth to rod outside.
Second CU for storage heaters, Also on a seperate Rod outside.
I have been told this second rod is not needed for the second board, Aslong as the resistance of the first earth on the 1st CU is within the reg limits (lower than 200 Ohms) then the first rod can also earth the second CU. Is this correct?
Ive measured the first main Rod to be 123 Ohms, I know its unusually high but its within the limits..
What do you lot think?
