Hi all.
Why does water and gas cause a major headache for electricians. Do we deserve this agro ???? The point of all this bonding conductor stuff ( as we already know ) is to cover ourselves from pipework that is exposed to human touch, getting a potential that could be harmful with reference to earth.
Tell me why plumbers aren't made responsible for ensuring their own installation is correctly earthed ?
Do what you can. As long as you can walk away from the site and be confident you've done what you are expected to do, then that's it.
I was told that if incoming pipework was not metallic ( so no conductive path back to earth ), then main bonding wasn't necessary.
But, like you say, what about radiators with a minimal amount of copper pipe work attached ? Well, just like previous wiring regs, which insisted that metallic windows and doors required bonding, things went just too far !!!!!
I would say that radiators fed from plastic pipework don't need bonding. As long as the situation is in writing describing this, then you are ok.
