Are my notches big enough? | Page 2 | on ElectriciansForums
Discuss Are my notches big enough? in the UK Electrical Forum area at ElectriciansForums.net
Sheffield
[ElectriciansForums.net] Are my notches big enough?
Found this beauty today, a 5 inch notch in a 6 inch joist.
It wasn’t me!
I felt sorry for the homeowner - and remember finding the exact same thing under my bathroom floor years ago.
Seen three 6" joists reduced to 2" across 800mm to allow a shower tray to sit flush with the tiled floor once. The kitchen ceiling below had a noticeable dip in it.
Plonkers !
Ok chaps and chappesses. How would you fix the problem without replacing the joist? I’d look at cutting a new block of wood to fill the notch and then fitting some sort of bracing plates that overlap some distance either side of the notch. Would even look at Acroing up the joist slightly prior to securing if there was any sag.
Yes, I agree..."sistering" would be the way to go to fix that...jack up, double the joists either side, and run steel plates either side with bolts through at about 50mm apart.
you don't need timber if fixing steel pates, so your brigantine is safe...... for now.
Reply to Are my notches big enough? in the UK Electrical Forum area at ElectriciansForums.net
Tile adhesive just not setting Hi all, New to this forum and an amateur DIY'r. Got a problem I'm hoping that someone can help me with as I'm...
superfuel
P
Reply to 'Im stuck wish my tiles were' thread Hiya I know this was 10 years ago hoping you still use the same email address and get this...
Purpzy
P
