Are these wires neutral? | Page 3 | on ElectriciansForums
Discuss Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I ran neutrals to my upstairs switches from the loft. Pulling 3C+E with T+E worked perfectly for all but one which it turns out ran through a couple of really tight holes drilled through the stud frame.
Some choice words were uttered when the tape snapped, but on the bright side I'm now a lot better at using my access rods than I was before!
Reply to Are these wires neutral? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
thank you so much. that worked out. i ended up shorting the live switch and sparks flew, but i recovered and its all working now. :)
You were correct those are neutral wires, it worked! Many thanks
