R
remer1957
The impact driver/wrench is so much quicker than spanners and sockets, plus I only need it and some ancillary bits and sockets in a pouch and I'm in business, no socket sets or spanners to lug around.
defiantly true, on trunking you can see it bending when using 8mm bolts if you over tighten it.
on rawl bolts i would rather use a socket set after using impact driver if they use very long bolts
we use 8mm bolts when bolting it to unistrut or 10mm rawl bolts into wall.Apart from trays I never drop below 10mm bolts for panel mounting or unistrut work.
same, i use them in brick as well.I use Rawl Bolts for non concrete walls too.
these?On the subject of fixings (hope I'm not off topic) I use fixings in concrete that just require a pilot hole, then are put in by the Impact Wrench, though I can't remember what they're called. They are quicker than the usual wedge anchors, though more costly, and don't require the carrying of any setting tool.
