Armoured Cable Question. | Page 2 | on ElectriciansForums
Discuss Armoured Cable Question. in the DIY Electrical Advice area at ElectriciansForums.net
Thank you for taking the time on a Sunday evening to assist me. If it is necessary I will instruct the replacement of this armoured cable although it will be a big job. Our safety is paramount of course.
Cable may not need replacing just wait for the second electrician. I suspect the reading they have stated is a high earth fault loop impedance (Zs) due to a breakdown of conductor continuity, this is an assumption though. If this is the case it may be possible to correct this.
Or something was left connected during the test, or it could just be a downright lie to get more money under false pretences from the OP.
You will have to excuse my synical thinking but there are a lot of people out there claiming to be qualified who have not got a clue
Thank you again Ung. He was introduced as a teacher (Electrics) and I always believed this and still do. Is there a way I can find out his qualifications? Please do not trouble to reply so late in the day but perhaps tomorrow if you do not mind. May I ask if you are Surrey based?
Don't worry about the time and day people will respond at all hours.
There is a saying that those that can't do it, teach although I do know a few good lads that went into teaching because they got fed up of crawling round sites in all the muck
Unfortunately not
This is relaxation time beer in one hand one finger typing with the other
Unfortunately not I live just off J24 of the M6 and the furthest south I get these days with work is Shropshire
Unfortunately not
I also have a beer in hand. You have helped me a lot. I hope I can now ask reasonably intelligent questions about this armoured cable and the alleged reading. What if I find it is not true! I am trying to give this man the benefit of my doubts but I am struggling.
Reactions: DPG
Just to try and get some perspective on this prior to the testing was this cable in service and operating normally if it was with the resistance figure quoted I'm thinking a decimal point may have been dropped or the MFT was setup incorrectly and gave a red cross in the display so was considered a fail by the tester
Approximately how long is this armoured cable and what is the overall diameter so we can try and identify the conductor size
The details of the cable are sometimes moulded into the black plastic covering… ie 2c25
Reactions: UNG
I have calipers and will measure in the morning. I would guess about 15 metres end to end but I can tell you tomorrow. It has been working fine but since it was condemned it has been turned off. I will upload some photos tomorrow which may help.
This is very helpful. I wonder if I can show these postings to my new Electrician. He is NICEIC Registered and he has been highly recommended. He is booked up in the early term but he will assist. The generous responses have been amazing and I am very grateful. I hope this will have a good and safe outcome.
If he knows his stuff he will fathom it out without us but we would like to know the outcome.
I think this would suggest that the guy who condemned it got it wrong somewhere
Good Morning Westward 10 - I wish to thank you and others you so helpfully gave up their time yesterday to respond. I will measure the armoured cable length this morning and try to identify the cable at the Oak Building Consumer end of the run (with it switched off having been made aware of the danger). I will take digital pictures I hope I can post. Of course I will advise on the outcome.
With a decimal point missing in the figure quoted is my thinking
This is a duplicated posting by me this morning Ung: Good Morning - It is a far more serious issue this morning as I have examined the Consumer Unit this morning and located the main armoured cable. It is more like 20 metres end to end. I discovered by lying down and look up with a torch that there is an earth cable no more than 2 inches in length cut off and in mid air. The live and neutral go to the main fuse. No wonder he advised of a risk of death. The obvious question this poses is if this earth cable is earthed both at this end and the other end (it may be) then will the Test Reading give a safe result? The Electrician recommended running a new armoured cable end to end. This would have been a huge high cost job but if this ultimately must be done to make it safe this is what we will instruct. I have not checked the other end and I stress again I am not an electrician but a 74 year old very worried home owner.
It is extremely hard to read the writing on the cable as the Power is off and I could only use a torch. It is 12 mm cable and it may read as follows:
FIECTRIP CABLE?
600/1000V
Coraka or similar?
Does this help?
Reply to Armoured Cable Question. in the DIY Electrical Advice area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
For a TN system neutral is deemed at earth potential.
