OP
stu_guy
using a quick rule of thumb on this one you could only have a round 11A on that circuit so would recommend a bigger cable i would personally use minimum 4mm 3 core
[h=2]RESULTS[/h]
i have a reel of 1.5mm 3 core armoured cable, i want to run it to a shed at the end of my garden, it will only be running a double socket and light switch,
n.b. the shed is about 60ft from the outhouse
[h=2]RESULTS[/h]
Phase | Single Phase |
Power | 2.53kW / 11A |
Length | 20m |
Core Size | 1.5mm² |
Voltage Drop | 6.82volts |
Calculate Another
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
