K
karen1965
Hi, i am using armoured cabling from fuse box in house to a workshop at end of garden. 40 meters away. a garage consumer fuse box unit will be used. This will supply wall plug sockets and lighting. Out door plug sockets will also be put outside the building to run a pond that is about 30 meters back towards the house. Should I use 4mm armoured cabling from house to workshop? Also do Ineed to use 4mm armoured cabling from outdoor plug sockets to pond. Or can I use.1.5 armoured cabling. Thanks for any help anyone can give.
