ASHP via sub main | Page 2 | on ElectriciansForums
Discuss ASHP via sub main in the Solar Thermal Advice Forum area at ElectriciansForums.net
Two circuits common in heat pumps, all depends upon the exact internal configuration.
Typically one for the compressor and one for the controls and backup heater.
Make sure they are on Type C breakers, ideally also ensure they have a soft start, else the start up current can be surprisingly high.
Appreciate you comment, especially about "C" type breakers. Yes I'm told that it will be soft start.
Reply to ASHP via sub main in the Solar Thermal Advice Forum area at ElectriciansForums.net
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
