Assessment Questions? | on ElectriciansForums
Discuss Assessment Questions? in the UK Electrical Forum area at ElectriciansForums.net
C
chrisgc
Hi
Just wondering on average (as know every assessment is not the same) how many questions and what questions are generally asked on NICEIC/Elecsa assessments?
demonstration of safe isolation, testing etc. questions on what to expect when you measure x.y.z. some tecchy questions you can look up if unsure. nobody knows it all. the main thing is showing competence and safe working at all times.
Hundreds mate. You will be grilled for hours until you are a sobbing mess on the floor, shaking in the foetal position....
Seriously tho, about 10-20 questions I would guess, half on BS7671, and the other half on the Building regs. Probably depends how well you answer as to how many the assessor asks. Can't remember all mine, as it is now a blur....
I was definitely asked about max zs for a 32A MCB, the 3 common types of supply, max. diameter of holes in a joist. I must have answered fairly well as I got an "A", though not sure exactly how.
Reply to Assessment Questions? in the UK Electrical Forum area at ElectriciansForums.net
Apart from ripcord and maybe a speciality flat elevator type ribbon cable I've also never seen a cable with two identical blue wires. I highly...
Thank you. I think I understand now.
