I went to do a simple job today, change a 5ft tube for an led fitting.
Changed the fittings, wired it, powered up and then nothing. The fitting is definitely working.
Checked the voltage, was around 110v at the fitting. Check the switch and got 230v. Figured it was the switch so I took that out of the equation and still 110v at the fitting. Wired in a ceiling rose with the s/l and neutral and still had the same 110v which disappears under load.
Am I missing something simple? I about ready to pull my hair out.
