Sparky83
....Pratt!
I was having a disscusion with a mate of mine and radials (like you do)
and we disagreed on on feeding a 2.5mm t&e from the 32a mcb of a ring ciruit.
I thought that you could only spur off the ring from a point on the ring itself like a socket, but he said you could take it straight from the mcb itself. To me this then becomes a radial circuit sharing a mcb with a ring main?
What would happen if the ring was removed and the radial circuit left, on a 32amp breaker, that would be right, so what makes it ok when a ring shares the mcb?
I've had a look about and even on this forum but some say its ok some dont. Im happy to admit im wrong, which is how it would seem it is but i would like a good explenation as to why its ok. :confused:
Cheers
Shawn
If you look at appendix 15 page 362 of BRB it shows various arrangements including using 1.5mm for sockets using a FCU ! Would I no, but it's there as table 6F page 134 of OSG shows the CCC of 1.5mm to prove it
Thanks for the P362 note - its clearly states that an unfused spur can be connected "to the origin of the circuit in the distribution board" which means that there would be 3 cables running into the protector (2 x 2.5 and 1 x 4.0). Thats how I read it!
Looks like I need a length of 4mm to add the double socket my customer wants.
No, no no:)
An unfused, 2.5mm spur off a 'Ring Final' can feed one single or one double S/O, even from the origin (MCB) of the circuit.
You don't need to use 4mm!!
At the risk of making myself look a bit of a.......
Australia
Sparky83,
WayneL,
