At the risk of making myself look a bit of a....... | Page 2 | on ElectriciansForums
Discuss At the risk of making myself look a bit of a....... in the Australia area at ElectriciansForums.net
Sparky83
....Pratt!
I was having a disscusion with a mate of mine and radials (like you do)
and we disagreed on on feeding a 2.5mm t&e from the 32a mcb of a ring ciruit.
I thought that you could only spur off the ring from a point on the ring itself like a socket, but he said you could take it straight from the mcb itself. To me this then becomes a radial circuit sharing a mcb with a ring main?
What would happen if the ring was removed and the radial circuit left, on a 32amp breaker, that would be right, so what makes it ok when a ring shares the mcb?
I've had a look about and even on this forum but some say its ok some dont. Im happy to admit im wrong, which is how it would seem it is but i would like a good explenation as to why its ok. :confused:
Cheers
Shawn
Addlights just saying that you can't add a 2.5 radial from a 32amp breaker protecting a ring.
A spur is one thing, a radial is something else
Is it still a spur when taken directly from the mcb? or is it a radial and a ring sharing a mcb???
In my other posts ive said radial but i guess it should read spur really.
But why is it OK to spur off a ring with 2.5 T and E?
A ring is used at 32A, when you spur off it you are using a 20A cable which because it is spurred off a ring is fused at 32A.
So why can you use a 20A cable fused at 32A?
One socket taken from the MCB is a spur.
To me a spur is one socket say and a radial is a number of sockets. This is where our confusion is i think.
Would it still be a spur if it was one FCU on the end of it?
As surely this would be a radial if fed from the consumer unit like a supply to a boiler/immersion heater?
Think you're taking the P now:mad:
I would sayit a spur if its sharing an MCB with a ring. On it own its a radial
Im sorry you feel that way, im in no way taking the P*** im trying to get something in my head that i dont understand.
But all im trying to find out if that if you have a 2.5mm circuit that feeds a boiler (or any fix appliance really) via a FCU for arguments sake and spare ways in your DB you would stick it on a 16a mcb. Yes?
So what then makes it ok to put that same circuit into a 32a mcb instead which feeds the ring and then call it a "spur"?
I get it if done from a point within the ring but not at the origin.
That is what i dont get!
"An unfused spur may be connected to the origin of the circuit in the distribution board" (433.1.5) - so it's okay by regs, but I don't like it when it comes to testing, as you have three cables at the MCB - the ring and the 'spur'. You can only properly test these as two circuits - do all you usual ring tests, then treat the spur as if it were a radial with one socket. Then you're faced with how to record it on the results sheet ... I'd rather try to find a way of putting the single socket on the ring as a 'proper' spur, or add it directly into the ring - or move to it's own MCB if there's enough ways.
Only joking sparky83
It has always seemed a bit odd that a 2,5mm wired as a spur from a ring circuit can be fused at 32A while a radial circuit supplying 1 twin socket wired in 2.5mm would have to be fused at 20A max......I think this is a case of the IEE simply accepting that it has been done this way since the dawn of time so it's best left alone.
i personally would not spur a socket direct from the fuseboard on a 32a its just a bit diy, but, even a spur direct from a 32a breaker into a double socket the max it could draw is 26 amps (13 amps per socket) if T+E is rated at 27 amps at best, the cable is not going to be overloaded. but say for example mr diy comes along and spurs 5 more sockets from that spur then you have a problem!!! just break into the ring or put it on a 20a mcb just makes sense to me!
Unfortunately, the regs are written and aimed at the competent person. No electrician in the world can plan for what the DIYer decides to do at a later date.
One reason why if we get questions on a forum asking 'how to do this and that' from a DIYer, then if they don't already have an idea, they should leave well alone.
Reply to At the risk of making myself look a bit of a....... in the Australia area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
