Atkinson tank top oil feed plumbing advice
Atkinson tank top oil feed As title anyone using one, good? bad? ugly? has to feed through a de-aireator to the boiler, but should not be a problem, my question is, should the oil line be insulated up the side of the tank, if so how do you attach the insulation to a plastic tank? Pipe being used is green PVC covered, would this be sufficient?
https://www.tanksrus.co.uk/assets/media/2024/04/26/atkinson-top-off-take-valve-datasheet.pdf
Atkinson tank top oil feed to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
MikeJhn,
