atlas copco air comp | on ElectriciansForums
Discuss atlas copco air comp in the Talk Electrician area at ElectriciansForums.net
dubai
hi guys hope all of you having a good time
my air compressor atlas copco GA11 FF is not running due to a fault a red light is in screen i try to reset many time but not gone
thanks for help
Do you mean the general alarm LED is on? Any of a thousand things could be wrong. Is anything showing on the display? If so, have you looked it up in the user handbook? There are different sections you need to refer to, according to which control system is fitted (Elektronikon I or II).
We had a similar problem recently with an Atlas Copco compressor, the fan in the VSD wasn't working and was causing the thing to over heat, it wouldn't reset until after it cooled down.
Have you got a good quality air dryer on your system.
Another problem, could be that you have mechanical damage on the air-end. This could be terminal for the whole compressor as it is uneconomical to repair.
Reply to atlas copco air comp in the Talk Electrician area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Thank you..... & did have all the fan isolator/ fuse in same plate (click) so quinetic wouldn't worked on this occasion
