T
Toneyz
To be honest, that's probably why a 13A moulded plug has not come attached.I1eff=14A is your effective load current so this is excessive for connection to a 13A plug top.
Discuss Attaching 13A plug on 20A appliance safety in the DIY Electrical Advice area at ElectriciansForums.net
If something isIf the 13A plug will fit the cable, then there should be no problem.
It’s only when you start welding thicker material that you’ll find the fuse blowing.
anthony is correct I think, most appliances come with a moulded plug attached, when something arrives without a plug it could be the manufacturers are trying to tell you, don't plug this equipment into a 13 A socket imoTo be honest, that's probably why a 13A moulded plug has not come attached.
Instead of rating all of my posts "dumb" in retaliation, perhaps you should accept that your post actually is dumb.If the 13A plug will fit the cable, then there should be no problem.
Isn't the connection made to the bottom of the plug? The top is usually just a safety cover feature.this is excessive for connection to a 13A plug top.
What exactly about it would be unsafe, if the 13A fuse would be the first thing to go wouldn’t this ensure that the garage wiring and everything else would be intact?
Strange how I’ve posted the same advice on the Screwfix Forum and the IET Forum, yet it’s only you who thinks it dumb?Instead of rating all of my posts "dumb" in retaliation, perhaps you should accept that your post actually is dumb.
The worst that will happen is that it won't blow with a small overload of long duration.as spin says. should be OK.try the bugger on a 13A plug. worst thing is the 13A fuse will blow.
Sorry, but that is rubbish.The worst that will happen is that it won't blow with a small overload of long duration.
No point trying to dress it up - it's very poor advice to give that this could be an appropriate way of connecting it up. It's wholly inappropriate. There's a reason it doesn't have a BS 1363 plug (aka plug top) on it.Sorry, but that is rubbish.
The very nature of welding, means that there is no long duration.
LOL. And you think that enhances your argument? Let's be honest - that forum is largely inhabited by the clueless and the clinically insane.Strange how I’ve posted the same advice on the Screwfix Forum
I and many others disagree.No point trying to dress it up - it's very poor advice to give that this could be an appropriate way of connecting it up. It's wholly inappropriate. There's a reason it doesn't have a BS 1363 plug (aka plug top) on it.
Reply to Attaching 13A plug on 20A appliance safety in the DIY Electrical Advice area at ElectriciansForums.net
