Attempting to future-proofing my in-home wiring | on ElectriciansForums
Discuss Attempting to future-proofing my in-home wiring in the DIY Electrical Advice area at ElectriciansForums.net
Suffolk, UK
Hi,
I'm having to re-wire almost my entire 3 bedroom house, which I know will be extremely disruptive (I'll be moving as much stuff out the house as possible, and hopefully moving out entirely for a week or so whilst a professional does the actual re-wire).
I have very little money to spend on anything fancy, but want to 'future proof' the rewire as much as possible in order to hopefully add some value to the house, or to ready it in case I get lucky with the lottery and can afford stuff in future!
So I'm thinking of doing the wiring for an in-house security system, an in-house multi-zone audio system, and in-house wired network BUT to have absolutely nothing connected to the ends. [I can't afford these systems at present. But the wiring will be there for the future, at least].
So my question is basically, how should I terminate the wirings in each room?
For example, if I had a CAT5c/6 cable run to the corner of my living room (for a future security camera, say), how should I terminate it initially? Is there a 'junction box with a blank panel' of some sort, that I could later 'connect to'?
Similarly for the audio cables (to many different rooms). I don't have the money to put in-ceiling speakers in yet, but could I terminate the speaker wire with a blanked 'connector' panel of some sort? [cheap, because it would be thrown away at some point when upgraded].
If terminated behind the ceiling or wall, I'd at least need some precise indication of where Id need to 'break through' to find the cable.
Do you see what I'm trying to do?
Thanks for your expertise and thoughts.
You can get various keystones for networking and AV, you'd terminate to those (no need to blank, just go straight to terminate) and then plug your accessories into the new ports provided.
Failing that just leave the wires unstripped to protect the conductors and use a "standard 1G 2G blanking plate.
Blanking plate; LAP 1-Gang Blanking Plate White - https://www.screwfix.com/p/lap-1-gang-blanking-plate-white/65793?kpid=65793&ds_kid=92700048793290388&gclsrc=aw.ds&ds_rl=1249401&gclid=CjwKCAiA58fvBRAzEiwAQW-hzdhywa5AF7bkLihxhWa4973v0790Fo81JSWaYZASC_ROqaq0R62euBoC-KIQAvD_BwE
Keystones;
Frames; LAP 1-Gang Front Plate with Double Module Aperture White - https://www.screwfix.com/p/lap-1-gang-front-plate-with-double-module-aperture-white/42092
You'll also find blanking plates in the above section too.
Bare in mind that a single backbox fits 2 modules and a double backbox fits 4
Reactions: DPG
Thanks for that.
I just didn't know the terminology (e.g. 'Keystone') so had trouble finding what I wanted on the web.
Thanks again.
Just put the back boxes in, leave the cables coiled in the boxes and put a blank face plate on.
Put more network cables in than you think.
I.e tv point wants 4 at the minimum
Smart tv
DVD player
X box
Sky box
They may all require a network point
Think about a point to each place in the house you might want a WiFi access point
Also, insist that a neutral is provided to every light switch point. Even if not used now.
Reactions: DPG
This would be for future smart switches that require a neutral to operate.
There are lighting circuits that only have a live and a switched live at the switch. Others have a neutral joint already in the switch box that can be utilised.
Thanks for all the added details. It all seems very sensible, but I would never have thought to specify it like this if you hadn't advised me.
Thanks a lot. :)
Reactions: DPG
Reply to Attempting to future-proofing my in-home wiring in the DIY Electrical Advice area at ElectriciansForums.net
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
Sounds more positive.
