Auto diallers + Red care | on ElectriciansForums
Discuss Auto diallers + Red care in the UK Electrical Forum area at ElectriciansForums.net
Hello,
Ive installed plenty of basic intruder alarm systems before but never done autodiallers or red care, i have a customer who wants a new alarm with these installed too, after having a read up on them they seem easy enough, but just after some advice from people who have installed these before?
Thank you.
Not sure you will be able to fit recare, you will need a central station that it calls back to, unless you do have one? The auto dialer is easy as long as, again, your not calling a central station.
In fact, that's probably a better starting point, who do you want the system to call/text?
Carl, this should be in the Alarms section but if your only talking about autodiallers I'll leave it in here because you dont have Alarm/cctv access. Please keep to autodiallers and not any engineering codes etc.
You may want to have a chat with Tazz, he has a great solution to your questions and they are very easy to install and set up. Send Tazz a PM.
You can fit any type you wish, but digicoms and redcare will require an account with a Alarm central station, which can only be used to contact customer or keyholders. You will need to be NSI or SSAIB registered for full Police response.
Reply to Auto diallers + Red care in the UK Electrical Forum area at ElectriciansForums.net
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
