- Reaction score
- 0
TITLE
Auto electrical mayhem please help!
1. Left rear indicator does not flash
Left front indicator flashes really fast
Right indicators both work & flash at normal speed
2. When hazards signals are turned on only the Left side both front front and rear flash at normal speed RIGHT SIDE DOES NOT WORK
I have replaced the relay fuse and flasher as well as all fues in the fuse box even though the fuse box diagram has nothing to do with lights and nothing had changed. When relay fuse is disconnected indicators and hazzards still flash in their faulty form which im told the shouldnt.I have tested all tail lights via direct connect to battery and even swapped right to left left works connected to right side
3. Head lights and high beams don't work by switch only Parker lights work headlights wired direct to battery work fine so those and bulbs are fine
Other notes: I left the Parker lights on by mistake a little while ago for about 5 hrs and returned to notice smoke and a smouldering wire which I believe to be a home made radio Ariel wire as since I have disconnected the battery I can no longer tune the radio and engine noise is present through the radio now.
As has been verified by toyota the vehicle which is a 1980 toyota hiace only has one fuse box any clues or help in the right direction will be great thanks
