Where does Regulation 131.2.1 state or even imply that an RCD provides basic protection?Because by definition basic protection stops the flow of current and also by definition an RCD provides basic protection regulation 131.2.1 says it does,
Electrical separation is in no way comparable to an RCD. This gives us two phase conductors with no neutral or Earth reference.How about electrical separation can this afford basic protection
But I don't accept that it is in any way ambiguous. That's why I am asking where precisely you believe that the Regulation in question supports your claim.Don't get me wrong I totally understand the principle I'm simply pointing out the ambiguity of the regs
Limiting the time isn't the same as limiting the current, though, which is what the Regulation stipulates.By time limited fault duration
No they don't. Ohm's Law is what you need.fault currents start at zero and climb in a time curve
