Automatic wire strippers | Page 2 | on ElectriciansForums
Discuss Automatic wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
Do they do bootlace crimps as well?
I have a pair of these although just with basic Red dipped handles
They are a bit small at first but used to them now
If you have problems with your hands then these probably won't help you
I use them for the small sizes of ferrules
ie upto 1.0mm only on controls anything for power or bigger than 1.0mm I use the knipex plier type which has indents
Had lots of people say they're no good for ferrules but when pull tested they hold just as well as those done with other tools at the smaller sizes
Lots of people say the ratchet type are better I think that depends on the quality if the tool ie Weidmuller versus Ebay cheapo and also the user
If it doesn't need to be calibrated then I think I pliers types are ok
[ElectriciansForums.net] Automatic wire strippers
I use an old set of Jokaris made in ‘west Germany’ for 2nd fix and when I can’t be tugging on wires and cables.
Second photo shows the more modern type (though broken in this photo from eBay) based on the design in the first.
Work very well and just need a clean of the jaws after a while so they grip the cable.
They do hate the silicone of FP and they dislike SWA insulation. Great for singles and T +E cores.
CK, cheap and easy, don't go right into back boxes, but ideal for first dressing or simply for preparing to connect to sockets
The best auto strippers I’ve used are a set of those cheap ones that look like a dinosaur.
Unfortunately, I attempted to use them to cut the T&E and one of the handles snapped in half.
Could be used for T&E and flex, though the length of stripped back sheath probably won’t suit many.
Top Tip..
Keep hold of them..
Don’t wait till you need them, start using them well in advance..
Especially if say, you have 200 flexes to strip and terminate a day
I got into the habit of using my CK autostrippers and use them regularly.
Pros,
Neatness
No nicks
Speed when doing large amounts.
Cons,
Can't get tight into back boxes so always leave a stump of sheath.
The wire cutters are next to useless so need two tools.
Anything above 1.5mm flex or 4mm T&E won't fit in the jaws.
Overall they are worth having and using but you have to get used to them.
That looks like a good price for the Strippers and I've been meaning to give the Quickwire jobbies a bash anyway.
The CK wire strippers are about £14 from Toolstation at the moment so I might just get both and see how they go. :)
I'm happy enough with the knife I have at the mo I use the Hultafors ELK and it's the dogs dangly bits.
I've tried all sorts of knives over the years and not got on with most of them but this one I can't do without.
Thanks for the replies Gents. :)
I have a knife I'm happy with TBH Pete.
Also as in the OP I need to find new methods of working to reduce the stress on my body while maintaining or increasing productivity.
At the moment I'm getting home and up in the mornings with new sore bits.
I love my job and have virtually zero transferable skills so if I want to keep up my productivity for as much of my working life as I can then changes need to be made before it's too late. :)
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Hi Ferg.
I once used those CK you mention from toolstation(they could of improved the mechanism or material)
I found them to sometimes strip the inner cores whilst taking the outer sheath off. Exposing copper!(and yes they were adjusted properly)
Not everytime but sometimes this would happen. Then in the end I think the cast jaw just broke whilst stripping some 1.5 twin.
Just a heads up but for 14quid they could be worth a go for yourself.
Reply to Automatic wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I need to rewire a mapping/traction control switch on a race bike that was damaged in a crash. The switch is not stock to install some other...
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
