automatic wire strippers | Page 2 | on ElectriciansForums
Discuss automatic wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
hey sorry i not replied
i was after some automatic stripers as
at college a while back i saw some one blitzing through 2.5 t&e for a assessment
the cutters cut the sheathing nice and straight
they then strip the inner cable without nicking the copper
the chap using them flew through the ring he was doing with no negative feed back regarding his t&w
all cuts were straight and neat
shame he failed as he didnt run a continuos earth in his lighting for some reason :S
Hello all (we are a sponsor advertiser so we are posting here but its not spam) please look at our scrap cable wire strippers at WS 200 ® UK Automatic Wire Stripper Tool, Don't Scrap it, Strip it! -...
clean copper wire or pipe £4.70/kg stripped
cable with insulation on £2.00/kg unstripped
Many Thanks Joe
Have a look at these mate.They are about £10 ex vat.All electrical wholesalers should stock them.I wouldn't use them personally.Hope this helps thou;)
Cable tooling specialist for tools, crimpers & cutters for the electrical industry
I had a pair like that. little farkers broke on me stripping 2.5mm 3 core despite them claiming to strip up to 6mm. also said from 0.2-6mm iirc. it was crap on anything that small.
now I do the same as OilBeDamned. snips up to 2.5mm, Stanley for anything over
I used to be able to do all of that with me teeth sonny !! ;)
Reply to automatic wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
I'd go for strippers every day, wire and cable are just plain boring! Definitely get yourself a stripper! (Failing that Id use ck crops)
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
