AV cables in solid wall - what the regs say? | Page 3 | on ElectriciansForums
Discuss AV cables in solid wall - what the regs say? in the UK Electrical Forum area at ElectriciansForums.net
Deuce
Stamford
Hi all,
Just being cheeky and asking for some advice really..
In my new house, we have solid walls throughout - great, but not so great for my home cinema kit. My issue is that whilst I would can chase the AV cables to wherever they need to be, I would prefer to do it in such a way that leaves the system open for future expansion. In the previous house we had stud walls and I was able to route flexible trunking between wall ports and pull through/swap whatever I needed.
In an ideal world, I would do something similar by cutting into the block, embedding some solid wall PVC trunking/pipe, and plastering back over. I can keep all my cuts continuous in either the horizontal or vertical, but my concern is what depth I'm allowed to cut into the block wall. Ideally I would need to go in to the block in 50x50mm channels to allow the space to run multiple feeds including moulded connectors... I'm not as regs savvy as you lot so thought I'd just ask the experts :)
NB for the mains power I'm chasing along separate routes to run the mains independently from speaker flex/hdmi etc.
Forgive my naivety but cant it all be wireless these days?
Bluetooth or something innit?
The problem is, that Bluetooth speakers need to have their own individual amplifiers built in. And a decent amp and power supply is around ÂŁ2k, whearas the tat they build in to Bluetooth speakers is probably worth more like ÂŁ10. Same as soundbars, trendy but a bit.. ummm.. crap
Not sure, doubt it. I was more thinking about regs regarding cut depth into the block wall. For the mains power to the TV I'm just gonna chase the cable in the normal manner, to a single low profile socket behind the TV itself.
Would the regs you ask about be the building regs then?
if you're got the money to install AV cables you're earning too much. ghetto blaster in living room, doors open, sorted. pink floyd throughout the house. any complaints, send them to bernados.
I live in a sleepy stone market town - the locals would burn me in the town square if I even purchased a ghetto blaster ;)
Not to mention my lovely wife... She's vicious!
Reply to AV cables in solid wall - what the regs say? in the UK Electrical Forum area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
Better off with the click prw213 as it has twin screw termination.
