Sparkysteve82
Can anyone give me a bit of advice on this please,
On an extension the original house has a Y-plan system installed and there are two new zones for wet system ufh being installed, however the new boiler (ehc eco-save) which is a combi and feeding the DHW and CH through a 3-port valve, only has volt free contacts, have been told off tech support that I will need a relay to convert switch lives into correct voltage for volt free contacts, do not have a great deal of experience with relays, any advice would be appreciated.
The ufh has been taken off before 3 port valve, will this need to be changed for two 2-port valves??
Steve
Steve
