B & B Design | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss B & B Design in the UK Electrical Forum area at ElectriciansForums.net
sparky87
Hi people,
Have a new luxury B&B to design and install and thought I would get thoughts on the design.
Internally it will have a dining area, hall, toilets and, 6 en-suite bedrooms (1 upstairs)
This is going to be a royal pain to wire as mostly is vaulted ceilings with baths located within the rooms!
My initial idea is to supply communal areas via the incoming 3 phase DB and then feed a 25Amp SP sub main to each room. Then wire 20A socket radial and 6A lighting from local DB for each room.
was thinking of using earth shield cable for the sub mains so no rcd required then rcd main switch in local DB or RCBO's for standard T&E final circuits.
Thinking of using local DB's for ease of wiring due vaulted ceilings and then each room will be independent of each other.
Any ideas etc would be much appreciated.
Thanks Adam
I could run individual radials directly from 3 phase db with rcbo's but problem is there would be at least 6 cables and in some areas in excess 10 which would need to be clipped within 150mm of the top of wall ajoining roof using T+E which would be a tad difficult!! also bunching/volt drop may be an issue. could use lsx all over but would work out very expensive in cable!
Go through the floor then
what about through the floor?
edit. Posted same time as dave.
Go with sub mains like you first said and go for SWA. Far better job. Less cables to run and you can omit RCD protection until the Sub DB which would localise any potential earth faults in future.
Because unless the card is used for entry......they will just leave the card in the energy switch, defeating the object of saving electricity..!!
Regarding use of floor, this cant be done as said block and beam with 100mm selotex, underfloor heating piping and screed which would be a nighmare to try and fit wiring in without thinking about ambient temp etc. Also underfloor being installed at mo with screed next week so no time!!
Reply to B & B Design in the UK Electrical Forum area at ElectriciansForums.net
Just re-read the OP's post and it is an existing 5C SWA so presumably a 3P supply. For 40A and 150m you are seeing 6.6V drop or 1.65% of 400V 3P...
Recommended Sponsor News
Hi everyone,
