Back box earthing | Page 2 | on ElectriciansForums
Discuss Back box earthing in the UK Electrical Forum area at ElectriciansForums.net
United Kingdom
Probably a bit of a noddy question but I am bringing my TV aerial cable into the house which I have already done. Now I want to fit a TV socket to the wall to tidy it all up.
I have purchased a metal back box with a plastic TV coaxial faceplate.
On the metal back box there is an adjustable lug for an earth. Do I need to install and earth from back box to faceplate or should it be fine without?
If so can I use any wire as an earth?
My bad...as the youngsters say!
but, for accuracy...ye actually can shove yer granny aff a bus...however I would not condone this...apparently this is rather non-PC...IIRC, it was envisioned that you could indeed shove your Granny off the bus, but not your mammie's mammie, but rather yer daddie's mammie...
I do feel that this distinction is unlikely to receive judicial approval in these enlightened times ...
….Time for you to walk the bleedin' plank...…….:)
Reply to Back box earthing in the UK Electrical Forum area at ElectriciansForums.net
As you said in #9 get an electrician involved. The information you are giving is not clear as you do not understand what is being asked which...
Also,if you had a duel box with a lighting cct on one side you would get a false reading.
