Back EMF diode | on ElectriciansForums
Discuss Back EMF diode in the UK Electrical Forum area at ElectriciansForums.net
S
surreysparks
What specific diode would I need for 12v DC locks, to reduce back EMF, as when you buy them on there own there is no diode unlike the paxton stuff etc that comes with one??
Well,
At a rough guess it is one of these Fail secure lock release, 12v dc fail secure lock release or similar, the diode is fitted in reverse parell with the supply, when the supply is turrned off circa 1 amp is going to flow for a small fraction of a second through the diode untill the energy is lost as heat in the winding of the coil. A very generous guess would be 10H for the coil so time constant of this circuit would be =10/30 0.333 seconds after 1 second the current will be virtually nill. This is totally within the capability of the 1N4002 I suspect I may have grossly exgerated the inductance of the lock and so the current will be cut off even sooner. This are typical diodes and so any silicon diode will act in about the same way.
A voltage dependent resistor would not be polarity sensitive, 0 12 the same as 12 0. Years ago 555 timer chips were triggered by a negative pulse to pin 2. This pulse could be tiny, so small that even a silicon diode at around 0.6V when forward biased by the back elf would not stop the timer from starting, the solution was to use germanium diodes which only have 0.1 V when forward biased. The point being the back elf is of the opposite polarity to the collapsing coil voltage so diode reverse biased with a small forward voltage would deal with problem better than a voltage dependent resistor which would do better giving generalised surge protection.Cheers
so all the manufactures of door access systems, such as ACT, Cardlock, Honeywell and manufactures of coil locks MEM, Eurolocks, Ducan supply varistors just for fun.....they suppress the high voltage spikes, diodes will block reverse emf, but will not suppress forward emf
What door entry system requires a diode for a back voltage then?
none I've come across in 27 years of dealing with them
but I await to be corrected
every days a school day n that
Hi thanks for the reply. I thought I had accepted in my last post that varistors had a role as General purpose suppressor. However because they are not polarity sensitive and also need to allow the circuits normal voltage they will not hold the reverse voltage down to 0.6V or.1V that diodes would. Cheers
As you keep pointing out reverse voltage, not high voltage suppression....this is why access manufactures prefer varistors to suppress high voltage. emf produce by a coil can only be ac, best you will achieve with a diode is high voltage...half rectified.
Reply to Back EMF diode in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
