Back in the day | on ElectriciansForums
Discuss Back in the day in the UK Electrical Forum area at ElectriciansForums.net
Oh yeah, however the alternative at the time was either surface box or severe hammer rash as you tried to recess the brick using a rawldrill/star-chisel - almost guaranteed it would be the only brick in the wall where they had used an engineering brick!
Or a loose brick which pushed the plaster out in the next room!
Last time I had that all the plaster fell off the whole wall, but as it was a kitchen, put up a row of tall wall cupboards, didn't have to chase for any cables. :cool:
The main problem was the plaster had lifted completely off the wall, so an extension collar would have been the only thing keeping the plaster in contact with the blockwork.
sack the plasterer then. :) :)
Never understood why folk want a dimmer - a device which provides dark, dingy or bright enough. We have one in my wife's craft room only because she bribed the electrician during building works to ignore me with his favourite coffee cake while I was out one day - even so it is only ever used in two modes - off and bright enough.
When dimmers 1st came out I did wonder if the lamps would last longer - being soft started with them.
(then the question became if the dimmer would outlive a cheap lamp !)
.. Not long after I treated my self to a Philips fluorescent ,including heavy magnetic choke in a stripy glass jar ..
Reply to Back in the day in the UK Electrical Forum area at ElectriciansForums.net
by the way.... these also come in dry lining box versions, and surface pattresses
Also,if you had a duel box with a lighting cct on one side you would get a false reading.
