Bad neutral on extraction fan? | Page 2 | on ElectriciansForums
Discuss Bad neutral on extraction fan? in the UK Electrical Forum area at ElectriciansForums.net
Cardiff
Hi all I've recently moved house and the extractor fan was not working, I've replaced the fan with a 240v extractor fan and wired up to my spotlights that are also 240v but for some reason the fan doesn't work. I've ran a new cable, tried 2 different extractor fans and definitely have 240v on the supply to the fan but it won't work and the lights do. Anything else I can try? Thanks
You ideally need a non timer fan but as in #14 this is a method to make it function, not a manufacturers prescribed method but nonetheless. As in #15 these works are notifiable to building control.
Hi all thanks for the replies and I tried a manrose extractor fan and it worked first time, guess it was 3rd time lucky.
Found the connection instructions online and they are incredibly clear.
Xpelair VX100 User Manual (Page 3 of 12) - https://www.manualslib.com/manual/1462959/Xpelair-Vx100.html?page=3#manual
If you are struggling with this I would recommend getting a competent electrician in. It could avoid damage to the new fan or worse, to yourself. If this work is in the zones of a bathroom it should be notified to building control anyway.
Hi Andy I've just gone and bought a fan without a timer, worked first time. Thanks
What happened to the initial fan supply?
New supply picked up from spotlights?
Stick a pin in it...…..3rd time lucky.....Well Done.
By the way....what's a bad neutral got to do with it?
Glad to know you got sorted safely. Sometimes it can save you time and money by getting a professional in, even for the small jobs. Maybe a thought for the next job ?
Reply to Bad neutral on extraction fan? in the UK Electrical Forum area at ElectriciansForums.net
Rcd protection?
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
