Bad practice or fine ? | on ElectriciansForums
Discuss Bad practice or fine ? in the Talk Electrician area at ElectriciansForums.net
stevie h
Got a rewire on at the mo and there is metal conduit for all of the original s/w drops , buried in the wall , the customer is happy with the original s/w positions so i was going to use the conduit to save chasing and mess , the conduit is not earthed , can i run my s/w drops in it ...? will be rewired to 17th..
cheers
Ste
you might have to change the boxes ,the face plate screws might be a different size,and the knockout in the new box might not line up,and on some boxes theres no earth terminal,also if its half inch conduit you will find it a bit tight for more than onec tae,but apart from all that using it should be ok
conduit not being earthed , and as i,v never used old conduit drops on a rewire before, so i thought i ask you knowlagable gents :)
sorry i thought you meant you were gonna bond them, if you bond them all i shouldnt think it would be a problem,
i would be supprised if the screws wernt the same size, usually all 3.5mm i thought, you can always drill a new hole if the KO didnt line up, and if for some odd reason they didnt have earth piller in the back you could put some in couldnt you? :)
Ref faceplate screws the very old ones used to be 4ba but they will tap out with a 3.5mm tap no problem, go ahead reuse the old conduits is not a problem ive done it for years, we dont earth metal capping do we ?
Regards dave
The original sw heights are not all exactly the same , so the plans is to drop them all a bit , so there spot on , so its down the conduit , out , short run of capping into new sw box .... so the conduit will not be getting an earth off the box , that is why i thought i,d double check .
As for the original sw boxes , there aint none , the switches are screwed via a sort of " u " shaped bracket mounted on the brick work and bit of wood , its very old , .... skts are single mk very old type mounted on the skirting , round pin inserts :eek:
Reply to Bad practice or fine ? in the Talk Electrician area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
