ballast | on ElectriciansForums
Discuss ballast in the UK Electrical Forum area at ElectriciansForums.net
M
m1ck_b87
Hi all
Today I had a major disaster connecting this ballast up in conjuction with the ignitor and still no joy any1 had problems with these or know how to connect properly I've added picture
  • [ElectriciansForums.net] ballast
It says on the ballast 1 and 3 are your 230v in or 1 and 4 if voltage is measured at 240....
No 2 is out to ignitor and then it says refer to ignitor for connection details.... how did you connect it.
Your ballast is universal for many different applications and lamps ... your Ignitor will have the correct wiring set-up for your lamp, if you show us the wiring plan on that then we can advise.
Reply to ballast in the UK Electrical Forum area at ElectriciansForums.net
There is a section on the mains supply which will give the type of supply as TNS, TNCS, TT etc this indicates the method of earthing
I think maybe it can be done with an arrangement of relays but need to think about the wiring ?
