OP
rumrunner
youre better staying where you are if youre going to collage,i dont know much about the work situation in your neck of the woods ,but if its industrial work you want ,try the JIB employment pool,you used to be able to ring up and they would tell you about all the vacancys in the area,also instead of sending out loads a cvs find a job you want and work out how you can get it ,then go and do it,try local builders ,plumbers ,etc,and tell them you need a day off each week for your course ,somone might help ,good luck and your right something will turn up ,chin up
