B
Batch
How come MICC glands don't with a banjo where as SWA does, yet both are required to the connected to earth or are used as a CPC?
Discuss Banjo in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
did a load of bare copper pyro on a furnace back in the 60s single cores and multi cores,we had to paint the galv tray with red oxide before cabling
It all comes down to theterminating into. If its a besa/metal conduit box and you are using the threaded spout then no banjo is required for either micc or swa cable.
Reply to Banjo in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
