Barbeque area supply | Page 2 | on ElectriciansForums
Discuss Barbeque area supply in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Hi all,
I need to supply an outdoor barbeque area with sockets and lights. (10m away from house)
Running a distribution circuit from the cu in house will be extremly difficult due to location.
The system is Tncs. House is 10 year old.
Im thinking of spuring off a socket on the downstairs ring main to supply a db at the barbeque area, not connecting the earth at the barbeque end but knock a rod in for the outdoor db.
Id like your thoughts please.
^^ bad idea. Not sure BS 7671 regs would agree with this.
FCU off RFC and bin the BBQ area CU is the way to go.
Im reluctant to go the fcu off rfc route as the loading might top this by a few amps on occasion.
How about opening the rfc up to incorporate the sockets outdoors and fcu the lighting from an outdoor socket.
Not a good idea.... always best to have a DP switch between the house circuit and the outdoors circuit so when the RCD starts tripping, the client can switch off the outside bit!
Yeah fair enough, but if you were to use a larger cable with 32amp capacity and also fit an isolator at the supply end I can't see a problem, just to give a bit more flexibility than the FCU would allow ?
Reply to Barbeque area supply in the UK Electrical Forum area at ElectriciansForums.net
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
